Good morning,
The 1201 is about your audio controls on the steering wheel. the most common failure for this issue is the clock spring under the steering wheel.
The U code, do you have navigation?
Information and Entertainment System
Pinpoint Tests
Pinpoint Test F: The Steering Wheel Controls Are Inoperative/Do Not Operate Correctly
Refer to Wiring Diagram Set 130 (Escape/Mariner, Escape Hybrid/Mariner Hybrid), Audio/Navigation for schematic and connector information. See: Vehicle > Electrical > Diagrams By Number
Normal Operation
There are 4 different steering wheel controls configurations:
- Non-navigation, without the SYNC system
- VOL-, VOL+, SEEK-, SEEK+, MEDIA
- All switches are wired to the Audio Control Module (ACM).
- Non-navigation, with the SYNC system
- VOL-, VOL+, SEEK-, SEEK+, VOICE, MEDIA, PHONE, OK
- The VOL-, VOL+, SEEK-, and SEEK+ switches are wired to the ACM. The remaining switches are wired to the Accessory Protocol Interface Module (APIM).
- Navigation, without the SYNC system
- All switches are wired to the ACM.
- Navigation, with the SYNC system
Voltage is sent from the APIM (or ACM) to the steering wheel controls, and the same module grounds the return circuit. The VOL-, VOL+, SEEK-, and SEEK+ switches share signal and return circuits, while the VOICE, MEDIA, PHONE, and OK switches share separate signal and return circuits.
For all configurations, when a switch is pressed, the voltage is routed through a specific resistor value for each function. The ACM (or APIM) then uses the reference voltage to determine which control input function has been selected.
B11BA:1C-B2404
This pinpoint test is intended to diagnose the following:
- Wiring, terminals or connectors
- Clockspring
- Steering wheel controls
- ACM
- APIM
PINPOINT TEST F: THE STEERING WHEEL CONTROLS ARE INOPERATIVE/DO NOT OPERATE CORRECTLY
NOTICE: Use the correct probe adapter(s) when making measurements. Failure to use the correct probe adapter(s) may damage the connector.
F1 DETERMINE THE INOPERATIVE STEERING WHEEL CONTROLS
- Determine which steering wheel controls are inoperative by pressing each steering wheel control switch individually while operating the audio system in various modes (AM/FM, SYNC (if equipped), etc.).
- Is the concern with the VOL-, VOL+, SEEK-, SEEK+, or MEDIA switch?
Yes
GO to F2.
No
GO to F3.
F2 MONITOR THE STEERING WHEEL CONTROL PIDs (EXCEPT NAVIGATION/SYNC SWITCHES)
- Enter the following diagnostic mode on the scan tool: ACM DataLogger.
- Monitor the steering wheel controls PIDs while pressing each steering wheel controls switch as follows:
Jan 3, 2019 at 6:49 AM
