Code B11db, after changing the water coolant flange?
2012 LAND ROVER RANGE ROVER
128,000 MILES • V8 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
which is under intake. Once done started the car it was a funny start after a minute the code came on. We had to undo the throttle body to do the job. Is this something related to it? Like a relearn? Or anything in the way if the intake we had to unplug that can cause that code?
Nov 19, 2024 at 6:11 PM
BORIS K
  • 836 POSTS
Fault code B11DB-87 Battery Monitoring Module - Bus Signal/message failure
This fault would be set in the Body Control module, BCM.
Unless you disturbed the positive supply to the battery sensor this should have nothing to do with the repair carried out.
Land Rover has a service bulletin for this fault, see link:
https://static.nhtsa.gov/odi/tsbs/2014/SB-10101194-9340.pdf
Cheers, Boris
Nov 21, 2024 at 1:27 AM
BHAMDOC1973
  • 2,008 POSTS
Yes, this is what is strange. I have not touched it. Woke up the next day, started it and it's now gone. Maybe some water had gone over some wires, that is my only explanations.
Nov 21, 2024 at 4:34 AM
BORIS K
  • 836 POSTS
Water could be a cause.
Suggest keeping an eye on it, if it comes back apply the information I provided earlier.
Cheers, Boris
Nov 21, 2024 at 7:04 AM
