Axle seal
2008 TOYOTA RAV4
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
I wanted to ask if the front axle shaft seal are compatible on both sides. I had called my local auto part store but they only have passenger side seal but I need to replace drivers side.
Aug 4, 2020 at 8:09 PM
STEVE W.
  • 15,113 POSTS
Which seals are you referring to?
Aug 4, 2020 at 9:05 PM
TOYPACIFIC
  • 159 POSTS
I notice a leak front drivers side CV shaft coming from the transmission seal.
Aug 4, 2020 at 9:48 PM
TOYPACIFIC
  • 159 POSTS
Two wheel drive, by the way.
Aug 4, 2020 at 9:49 PM
STEVE W.
  • 15,113 POSTS
Okay, in that case there are two different transmissions used. However in both versions the left and right seals are different. It isn't a big difference as it amounts to 1 mm difference in the thickness of the seals. The left side is 7.5 mm thick while the right is 8.5 mm.
Aug 4, 2020 at 11:01 PM
TOYPACIFIC
  • 159 POSTS
Got you. thank you for this information.
Lol I'm a back yard mechanic still learning everyday but thanks to you guys I can learn more. I appreciate it.
Aug 4, 2020 at 11:12 PM
STEVE W.
  • 15,113 POSTS
You're welcome. Thank you for using 2CarPros.
Aug 5, 2020 at 6:33 AM
