Replacing axles and need to know for sure how many splines are my axles 33 ?
Apr 15, 2026 at 5:39 PM
CERTIFIED EXPERT
You can remove the old axles and count them to be sure but it says, "applications show 33 outboard splines and 34 inboard splines". Let us know if you need anything else.
Apr 16, 2026 at 9:39 AM
TJMOWBRAY
MEMBER
Ok thanks Ken l any seals I need to replace or anything else I should know
Apr 16, 2026 at 11:52 AM
CERTIFIED EXPERT
You can replace the transaxle seal on the side you are replacing the axle on which is common practice.
Apr 17, 2026 at 7:33 AM
TJMOWBRAY
MEMBER
What's the procedure?
Apr 17, 2026 at 7:36 AM
CERTIFIED EXPERT
Once the CV axle is removed, use a seal remover and pop the seal out then use a seal install tool to tap the new seal into place then coat the seal with transmission oil before installing the new CV axle.
