Axle nut different
1998 TOYOTA COROLLA
2,000,000 MILES • 4 CYL • 2WD
ADAM RUDEN
Replaced driver axle and it came with a different nut. The nut has no spot for cotter pin. I torqued it correctly. But can't get it past cotter key hole. I also did bearing and hub.
Aug 5, 2019 at 1:59 AM
Hi Adam,
Did the axle nut that did not have the cotter pin have some other way of preventing it from loosing? Like a lock washer or anything? If not, sounds like the wrong axle nut. I would recommend calling the supplier of the part and telling them what it is doing so they can tell you if that was as design. If not, I would reuse your old nut and use the castle lock cap and a cotter pin. Long story short, you don't want to risk that loosening.
Let me know if you have questions or what the supplier says. Thanks
Aug 5, 2019 at 4:39 PM
