Can I swap out an AWD and put in a 2wd transmission?
Jul 17, 2020 at 3:24 PM
CERTIFIED EXPERT
Good evening,
Yes, you can but you will have to have the PCM reprogrammed to a front wheel drive. If you do not, then you will end up with a lot of codes in the system.
Why do you want to do this swap? Is there an issue with the rear differential?
Jul 17, 2020 at 4:29 PM
DAN FLORES
MEMBER
Just hard to find AWD transmission. found out that 2wd are less expensive (half the price).
Jul 18, 2020 at 5:43 AM
DAN FLORES
MEMBER
How hard would it be to reprogram PCM?
Jul 18, 2020 at 5:46 AM
CERTIFIED EXPERT
Okay, can I have the VIN number so I can see if I can get or locate a transmission for you?
