Well I know that if you have two different size tires on the vehicle that it can throw off ABS and AWD systems, causing general havoc as the ABS and traction control module will see different wheel speeds at the same time. But if you have all four tires the same size, then that is not the issue. I will say that neither size is the proper stock size for that vehicle. Sizes should be either 215/70/R16 or 225/60/R17.
A failed wheel speed sensor could be an issue and could be why they replaced a bearing/hub. If it was a hub assembly (which it probably was) then that would have come with a new sensor.
That light being on indicates that the system has set a diagnostic fault code. You might try unhooking your battery for ten minutes and then hooking it back up. That will clear out any trouble codes and data and give the computer a fresh start. Maybe, just maybe, the light will not come back on. It probably will though. If it does come back, you may have to take it to the Chevrolet dealership in your area and see what codes they can.
Do that and let us know what you find.
Dec 19, 2017 at 7:29 PM
