Bogs down when pressing gas pedal
2003 CHEVROLET AVALANCHE
130,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
It starts up, goes to 2,000 RPM's then if you give it gas it shuts off. If you don't do anything it steps down until stops. Thinking sensors or thinking fuel filter/pump?
Mar 18, 2019 at 8:51 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's throttle body being dirty. When your vehicle's throttle body gets gunked up with "tar" looking substance, which is normal from air flow over time, the Throttle Position Sensor (TPS) has a hard time communicating how much the actual throttle plate is open to the Power-train Control Module (PCM) AKA,"computer". When the PCM gets varied or mixed signals it will go into "limp" mode to get it to a shop to be fixed. Engine's are essentially air pumps, as the air to fuel ratio ideally is 14.7 parts air to 1 part fuel(this is because at sea level the earth's atmosphere is exactly 14.7 miles high), so going lean, that is adding more air to the mix, is a sure fire way for internal engine damage.
I have included a couple of links for you down below:
https://www.2carpros.com/articles/how-a-throttle-body-works
Please go through these links and let us know what you find out.
Thanks,
Alex
2CarPros
Mar 18, 2019 at 11:24 AM
