Automatic Transmission Temp triggers during climbing long hill
1998 TOYOTA LAND CRUISER PRADO
179,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
JIMMY GAN
My Toyota Prado instrument panel will trigger A/T OIL TEMP on when climbing long hill. As the car climbing, the radiator temperature remains the same. Once I drive down hill, the A/T OIL TEMP indication ultimately will disappear. I believe this indication is genuine but I don't know what is the root cause problem. I with your experience can consult me for a solution. Thank You.
Nov 11, 2015 at 5:21 PM
DOCHAGERTY
  • 9,603 POSTS
Condition of fluid may have importance. Replace filter and flush trans fluid and see if that works
Nov 11, 2015 at 6:54 PM
JIMMY GAN
Automatic transmission fluids had been replaced including the filter but the problem still persist. I suspect radiator need to be change also. What is your opinion?
Nov 11, 2015 at 7:01 PM
DOCHAGERTY
  • 9,603 POSTS
I would probably ignore it.
If the company has a directive for this issue, it will be "google-able"
Nov 11, 2015 at 7:16 PM
