automatic transmission shift problem
2001 MITSUBISHI SPACE WAGON
233,333 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
JADDUN
  • 26 POSTS
This car's engine was replaced with a 2000 Mitsubishi gallant engine and now the automatic transmission keeps reviving up once it is in gear three before engaging and revs up at exactly 50 km/hour then same thing when slowing down too.
Sep 24, 2016 at 6:17 PM
HMAC300
  • 48,601 POSTS
scan for codes first see if there is an electrical problem.
Sep 25, 2016 at 8:25 AM
RENEE L
  • 1,260 POSTS
Hello JADDUN,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Sep 25, 2016 at 4:49 PM
JADDUN
  • 26 POSTS
hi, was able to retrieve these codes : 12- throttle position sensor system; 13; 14- acc pedal position sensor system; 21; 23; 25; 56; 79; 78; 77; 91.
Sep 26, 2016 at 2:54 PM
HMAC300
  • 48,601 POSTS
we do not have those number codes for that year so you must be not In USA with that many codes check battery for condition including load test as they may be false codes due to a weak battery.
Sep 26, 2016 at 3:31 PM
JADDUN
  • 26 POSTS
ok its: accelerator pedal position sensor system open circuit.; crank angle sensor system; oo
Sep 30, 2016 at 12:30 PM
JADDUN
  • 26 POSTS
output shaft speed sensor system; wide open throttle switch system; n range lamp system;
Sep 30, 2016 at 12:35 PM
Please clear the codes and then drive it for a short time and regather codes, we are just trying to get the most prevalent codes first. This will help narrow the problem down.
Please let us know what you find so it will help others.
Best, Ken
Oct 1, 2016 at 10:37 AM
JADDUN
  • 26 POSTS
same codes reappear or maybe it refused to clear. but I read in the manual that if the output shaft speed sensor is recorded 4 times it goes into a fail safe mode @ gear 3. so maybe that's what has happened. just maybe
Oct 2, 2016 at 10:39 AM
HMAC300
  • 48,601 POSTS
then try to replace it or check for wiring shorting out. but with your miles i'd think it would be more of a clutch pak bad and trans slipping
Oct 2, 2016 at 11:38 AM
