I recently changed Transmission Fluid and Filter and and all of a sudden Trans Fluid started leaking from top of Transmission itself where you fill the Fluid, at first it was just a small leak and i thought it was an O-ring from the Cap itself but after replacing the O-ring multiple times because i purchased a package O-ring gasket from Home Depot, the Trans Fluid still leaks and now it is really gushing out as soon as you start the engine. I even went to junk yard this weekend and pick up 5 of this Trans Fluid Cap and replaced them and still No luck , the fluid still leaking a lot, our local Chevy Dealer Part dept is closed on weekends and really need to use the car by Monday and thats the reason i had to go to Junk yard, Do i really need to buy a brand new Trans Fluid Cap for this car , I'm having doubt now that i got 5 used one's from the junk yard, is there some kind of pressure mechanism inside this Cap, by the way the Cap itself has some kind of Air vent hole in the middle of Tread when you screw in the Cap and a small hole at the side of the Cap and i guess for Air to come out, but instead that's where the Trans Fluid comes out from the Cap. Any input is appreciated, thank you.
Apr 3, 2016 at 4:24 PM
