automatic transmission fluid change?
2010 HYUNDAI SANTA FE
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE1953
  • 772 POSTS
transmission doesn't shift smoothly at low speed, and at 0 MPH the transmission makes a noise.
Jan 3, 2025 at 12:39 AM
BORIS K
  • 836 POSTS
A noisy transmission and shifting issues can be caused by dirty or low transmission fluid.
Suggest checking transmission fluid level, also check for possible transmission oil leaks.
How to:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
How to service:
A video how to replace transmission oil, on a diesel but will also apply:
https://youtu.be/DN2Zv8RK22g?si=z4ULP1RrjJfdXL6E
Hope this helps.
Cheers, Boris
Jan 3, 2025 at 1:53 AM
JOE1953
  • 772 POSTS
how do i check the fluid level? I don't see a dipstick. how much fluid does it hold after changing it and what type?
Jan 3, 2025 at 4:58 AM
There should be a drain plug on the side of the case, or a drain plug on the pan that needs to be removed and then pumped in and then it will run out until it stops, which will be the fluid level. Please go over the guides Boris posted.
Fluid Types
Updated by TSB 13-AT-011
Automatic Transmission Fluid Type
Type .................... SP4-M
Capacities
Automatic Transaxle Fluid
Capacity .................... 8.24 qt (7.8L)
Let us know if you need anything else.
Jan 5, 2025 at 11:49 AM
JOE1953
  • 772 POSTS
do I have to add anything else to the fluid when I change it? Where is the best and cheaper place to buy fluid? I priced some Valvaline Import full synthetic at O'Reilly and it was $13.00 a quart.
Jan 5, 2025 at 1:38 PM
I would try Amazon.
Jan 6, 2025 at 9:42 AM
JOE1953
  • 772 POSTS
which one of the plug on the pan is the fluid level and drain plug? one is at the front, and one is on the side like. I tried to check the fluid level by removing the plug at the front of the pan with the vehicle on jack stands and engine Idling in park and I remove the plug at the front of the pan, but nothing didn't come out is this the way I check fluid level? There is also a plug on top, is that a fill plug too?
Jan 10, 2025 at 7:04 AM
Can you upload an image of the fill plug you think is the fill? The fact that no fluid came out is telling me that is probably the way they fill and obtain the fluid level as well, that is common on newer cars.
Jan 10, 2025 at 9:41 AM
JOE1953
  • 772 POSTS
Is the 8.24 qt just for the pan fill and converter too or just the pan fill?
Jan 11, 2025 at 8:21 AM
That should be a complete fill with the converter.
Jan 11, 2025 at 9:15 AM
JOE1953
  • 772 POSTS
when I drain the pan the converter drain also ?
Jan 11, 2025 at 9:46 AM
I don't think this transmission has a drainable converter.
Jan 13, 2025 at 12:38 PM
JOE1953
  • 772 POSTS
how do I upload an Image?
Jan 13, 2025 at 4:34 PM
There is a link at the bottom of the text box that says " Add image or video " then use you phone to take an image and upload it with your response.
Jan 14, 2025 at 10:17 AM
