Automatic transmission fluid
2002 RENAULT KANGOO
55,000 MILES • 2WD • AUTOMATIC
FI WALKER
Hi, my automatic car listed above will not change gear going up hill unless I take foot of pedal and repress. It also clunks when changing. Does this indicate the transmission fluid is low?
Also, where do and how do you check on this model? It is a Renualt automatic.1.4. M reg. 2002.
Thanks. Fi.
May 7, 2017 at 12:03 AM
it sounds like you have a catalytic converter that is partially plugged. When this happens it lowers the engine vacuum making the transmission shift hard and late. Here is a guide to help you see if the cat is the problem.
Please run this test and get back to us so we can continue helping you.
May 9, 2017 at 11:58 AM
