I recently purchased the truck listed above flex fuel. I purchased it with the understanding the transmission (4r44e) was bad and there was no reverse gear. I installed another 4r44e, filled the fluids to spec, and when I tried to operate the transmission there was no response (idle/rpm reduction in R, D, 2, and L). Upon troubleshooting I happened to notice there were numerous fuses blown and on the fuses which tested "good" the prongs were scorched and looked like there was an extreme power surge. One of the blown fuses was to provide power to the OBD II port. (I connected my code reader and there are no codes to read.) While the engine was idling, I noticed the battery voltage gauge indicator needle was not moving at all. I also notice I have had to jump start the vehicle the last few times I started it, whereas I had not when I first purchased the vehicle.
I'm assuming my alternator is bad, but what would cause approximately 5 fuses to blow and scorch the remaining? Is there a correlation between the transmission not engaging any gear (all the forward gears operated well, just not reverse) and the electrical issues?
Any direction on where to begin finding root causes would be appreciated tremendously.
Thank you.
Thank you.
Nov 25, 2023 at 5:02 PM
