automatic transmission does not work?
2012 CHEVROLET MALIBU
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SRDJAS
  • 6 POSTS
Hello, my automatic transmission doesn't work! It stays at 1st gear and won't shift.
Errors displayed are:
P0013
P0700
P0766
P0324
P0326
Can i repair it or do i need new?
Aug 23, 2023 at 2:53 PM
Let's go through each code:
P0013 - Camshaft Position Actuator "B" Control Circuit/Open (Bank 1):
P0700 - Transmission Control System (MIL Request):
P0766 - Shift Solenoid "D" Performance or Stuck Off:
P0324 - Knock Control System Error (Bank 1):
P0326 - Knock Sensor "1" Circuit Range/Performance (Bank 1) or Sensor Performance (Bank 1):
Here is how to change the shift solenoid out to fix the problem. Please start a new question for the additional problems we only handle one problem per thread, please post your new question here, you must be logged in.
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 24, 2023 at 12:34 PM
SRDJAS
  • 6 POSTS
Is it usual to change oil after a transmission repair? My service wants to change oil after 2,000km...
Nov 6, 2023 at 1:27 PM
Yes, it is a good idea to change out the fluid when doing the repair.
DEXRON-VI Automatic Transmission Fluid.
Please let us know how it goes.
Nov 7, 2023 at 8:35 AM
SRDJAS
  • 6 POSTS
They already changed the oil and did repair. Now they want to change it after 2000km driving. Couse new parts make a lot of dirt.
Transmission doing fine, but when i put in R i feel a slight vibration, that only lasts a second.
Is this common?
Nov 7, 2023 at 9:28 AM
It depends on the vibration, a slight vibration is normal but if it is uncomfortable, you could have a transmission or engine mounts going out, can you upload a short video of the problem so I can see? You can upload it here with your response.
Nov 8, 2023 at 8:41 AM
