Hi Brucem,
I would put my money on the fact that you are going from the auto transmission using a park/neutral safety switch to a clutch pedal position switch.
If you did not do anything with the PCM then it is still looking for a the P/N switch on the side of the transmission. It is not seeing that so it will not allow it to fire which it will do by not delivering the spark.
I included the info for both the P/N switch and the clutch pedal position switch. My guess is the way to do that is you need to put a PCM in the vehicle that is set up for a manual trans. Or at least tell the PCM that it is now a manual transmission. There may be some programming tools out there that do that, but I am only aware of replacing the PCM with one set up for a manual.
If you already addressed this, then let me know and we can go further.
Apr 26, 2019 at 11:40 AM
