I changed the 7.5 fuse under the hood, and it was working again. After about three days or so the fuse blew out again. Then I went and changed it again and it did the same thing. Why does the fuse keep blowing out and what can I do to fix this problem for good? Is it okay if I put a higher amp fuse in like a 10amp fuse instead? Or will that cause more problems with my electrical system?
Mar 4, 2022 at 11:43 PM
