The in vehicle auto trunk release switch (nor the key fob) will open the trunk. Key opens trunk - OK Also the cyclops stop light located on the exterior of the trunk is not working. I have read that both problems are usually related to broken wiring within the flexible wiring loom running between the passenger side interior trunk - to the chassis. There is a flexible wiring harness protector covering the wiring. Each end of the protector is fitted with a flexible rubber boot. I have removed both boots and tried to slide the protector each direction to make a visual inspection of the wires. I have been unable to see any breaks or bad insulation, however the protector has no split to remove it entirely for a complete visual inspection. I have not read of or found any fuse for the trunk release / cyclops brake light circuit. Any suggestions?
Nov 29, 2013 at 9:39 PM
