auto transmission
2004 NISSAN TEANA
205,000 MILES • 2.3L • V6 • FWD • AUTOMATIC
MOSES YAMR
What is the best ATF for the car listed above? It is a petrol J31 engine.
Can a little drop in the level of the ATF oil cause some slippage in corners and when uphill?
How long can the ATF for the car be used before change? i have used mine for at least 80,000 km.
Jul 31, 2017 at 11:41 PM
I couple of things, first you must use factory fluid in those truck do not use regular transmission fluid or the transmission will not work. Second it time for a service here is a guide that will help you get the job done.
you will need to jack up the car.
Aug 2, 2017 at 2:55 PM
