Transmission works fine hot or cold for thirty seconds or so all gears and reverse. Then it is like its in neutral.
Turn it off, let it sit for one or two minutes, runs fine all gears then it is like its in neutral.
Fluid looks fine and does not smell burnt.
Shift linkage looks fine at transmission.
Codes are 0700, 0730, 0740.
Tested resistance all exterior solenoids they meet specs.
Applies voltage to each they click.
Removed each checked screens and spool movement they check okay.
Fluid level okay.
Temperature sensor works fine compared to temperature gauge.
Checked all solenoid connection seem okay.
Each time i start it it works okay for thirty seconds to a minute then it is like it is in neutral all gears.
Fluid level okay.
Jan 21, 2019 at 9:30 AM
