auto tranny
1990 OLDSMOBILE CIERA
70,200 MILES
ROGER6632
  • 19 POSTS
i fill my tranny to the full line and in 3 days the stick shows empty
i put 1 and 1/2 quarts in empty in 2 0r 3 days.no oil spots on ground
nothing wet on tranny or under car,where is it going? its a 4 speed auto
May 5, 2013 at 6:22 PM
HMAC300
  • 48,601 POSTS
check to see if your radiator has oil in it the cooler line in radiator may have broken
May 5, 2013 at 6:24 PM
ROGER6632
  • 19 POSTS
i checked the radiator no oil,i had the car for a year it did this all the time
any more idea,s?? tranny is dry,under car is dry,no wet stops on drive way
May 6, 2013 at 9:27 AM
HMAC300
  • 48,601 POSTS
if trany is dry it has to be going into radiator or ithe vacuum modulateor if yo have one is bad and is being sucked into the engine. the modulator would be on the back side of trans.
May 8, 2013 at 7:24 AM
ROGER6632
  • 19 POSTS
if it is the vacuum modulator where does it go after it gets in engine?
out the exhaust? thanks
May 8, 2013 at 9:43 AM
HMAC300
  • 48,601 POSTS
it gets burned up through the engine so you aren't going to notice it.
May 8, 2013 at 10:17 AM
