Go here and get the owners manual -
https://www.kiatechinfo.com/ext_If/kma_owner_portal/content_pop.aspx
Read through it because there are a ton of things on that car that were not on your old one. Some of which can be messed up simply by putting a sticker on the car in the wrong place!
And here to get the features guide -
The basics are that your car has electronic parking brakes, no cables. The auto-hold uses them to apply the brakes whenever the car is running but stationary. So, like you come up to a traffic light and stop. In most cars you would set there with your foot on the brake. With auto-hold on, you don't need to hold the brake, the car will just set there. BUT it does not turn on the brake lights when you release the pedal. So, in the old car those lights told someone behind you "HEY that car is stopped" and they would slow down. With the auto-hold there are no lights, so to me that "feature" is not all that safe. The switch is probably not a real switch but a capacitance switch like the ones used on touch screens, just a light touch makes it work.
Jul 22, 2025 at 11:52 AM
