Auto car does not move forward after releasing brake pedal
2007 HYUNDAI ATOS
56,000 MILES
DEVPILLAY
Hi, when my car is in drive and I stop the car on a level road, the car remains stationary even after I take my foot of the brake pedal. Then I have to press on the accelerator for it to move. Being an auto transmission, the car should start moving forward slowly as soon as I release the brake.
May 20, 2013 at 11:23 PM
MHPAUTOS
  • 31,937 POSTS
You may have a tight brake, can you easily push the car in neutral? on the flat it should move very easily once it gets going.
May 21, 2013 at 4:05 AM
DEVPILLAY
Hi, yes I can easily push my vehicle when it is in neutral.
May 21, 2013 at 4:43 AM
MHPAUTOS
  • 31,937 POSTS
May be low lie pressure, problem with the transmission oil pump or the governor, low liner pressure will not drive the transmission.
May 22, 2013 at 4:10 AM
KISSAB16
Cause I have changed the transmission oil pump but the problem has not been solved.
Mar 19, 2026 at 11:18 AM
I have seen the transmission clutches being burnt up which will cause this issue, also make sure transmission fluid level is correct, can I ask if the engine idle is supe low, like at 400 rpm?
Mar 20, 2026 at 8:22 AM
