Have you checked the fuses as recommended above? If you find they are both good, we will need to get into the wiring at the integrated power module. However, if the radio isn't turning on and off or glitching on and off when this happens, chances are the radio is going bad.
Ken attached the entire wiring schematic above, so you can refer to that. However, I need you to pay attention if there is anything noticeable on the radio that could indicate a power issue such as a flicker in the backlight.
I want you to check one more thing. Everything related to the system has a common ground. If you look at the pic below, I circled the ground and it indicates location.
Check that to make sure nothing is loose, corroded, or damaged in any way.
Let us know.
See pic below.
Apr 24, 2021 at 6:34 PM
