I have a Denali, I converted the stereo system to a 2003 model in order to put in a double din touch screen. I wired up everything with the harness I was told would certainly work for the Bose system. I hooked up the system and it work for ten minutes. I thought at first it was the double din, but once I took it out and put the factor Bose system back in it also did not operate. I checked the fuse under the hood and also the side panel and they are all good. Also once plugging my climate controls back in the dapper is not operating properly anymore and will only blow out are through the defrost vents. My fuel display is also not operating as well. I am really confused on what to do and how all this happened at once. Is there a relay somewhere I missed or how where else can I look to see if it is getting direct power?
Jul 24, 2017 at 1:20 AM
