2000 Audi Quattro car doesn't blow very hot heat
2000 AUDI QUATTRO
134,000 MILES • 4 CYL • AWD • AUTOMATIC
BILLYBUCK60
the heater used to work great as of late,all the controls work fine but the heater doesn't blow very hot air.also my coolant temperature needle also shows the car running cooler than the normal temperature used to be.
Sep 22, 2008 at 7:35 PM
Replace the thermostat-the reason why its getting cooler is the thermostat is not doing its job its probably stuck open-also not providing more heated coolant to the heater core where you get your heat from.
Good Luck
Sep 22, 2008 at 7:52 PM
