electrical problem
AUDI A6
CSTRAT
I have a '02 A6 Quattro with memory seats. When I hit the button for any of the three options nothing happens unless I hold the button down until the proper position is reached. Also the signal horn for the lights no longer sounds when the engine is turned off and I leave the lights on. I thought it was a fuse, but all of the fuses are good.
Nov 4, 2007 at 9:30 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I feel that both these faults should register a fault code in the body module ecu. Check your owners hand book for any re learn capability for the seat position set. I will also do some home work and re post any findings.
Mark (mhpautos)
Nov 16, 2007 at 8:45 PM
