audi a6 2.7 turbo
AUDI A6
POU
2001 Audi a6 2.7 T mileage at 89000
Approximately how much should it cost to replace timing belt assuming you also replace water pump, tensioners etc.? Is it necessary to have special tools? Is it necessary to remove front bumper? Is it necessary to repleace water pump and pulleys? :?:
Jul 10, 2007 at 12:05 PM
2CARPRO JACK
  • 11,533 POSTS
You are probably looking at anywhere between 800 and 1000 dollars depending on the hourly rate of the shop and if all tensioners and idlers are replaced. My software mentions a few specialty alignment tools req'd to hold th ecams and crank in alignment, and it also says that removing the bumper is req'd
Jul 11, 2007 at 2:10 PM
