2003 Audi A6 lights out
2003 AUDI A6
RDXWKPR
Electrical problem
2003 Audi A6 6 cyl All Wheel Drive Manual
My driver side head light is out. Tested the bulb, works fine. Tested the voltage on both sides, it's at about 5 volts. What else can be wrong here?
Aug 16, 2008 at 1:24 PM
KHLOW2008
  • 41,814 POSTS
Hi rdxwkpr,
Check the headlight fuses, one could be blown.
Aug 21, 2008 at 10:14 AM
RDXWKPR
But if I have the same voltage how could a fuse be out? I will check that out.
Thanks
Aug 21, 2008 at 1:50 PM
KHLOW2008
  • 41,814 POSTS
Hi rdxwkpr,
Each side uses separate individual fuses and both circuit are interlinked so when 1 fuse blows, power is now shared by both with one side in reverse flow thus 5 v is present and not 12 v.
Aug 21, 2008 at 7:21 PM
