2003 Audi A6 Brake Lights Seize
2003 AUDI A6
68,000 MILES • 6 CYL • AWD • AUTOMATIC
DOUBLEMANN
My brake lights won't go off when I shut off the engine. I have removed the fuse that controls them (and all the internal dash lights) and it does not appear to be the fuse. The rear light panel works properly for blinkers and headlights and brakes appear to be fully functional.
Help please? Any ideas where to start?
Doublemann
Dec 25, 2007 at 12:54 PM
BLACKOP555
  • 10,386 POSTS
sounds to me that your brake on/off switch is improperly adjusted. when the brake is depressed the switch is opened causing the lights to come on, so if its bent and its not making the button push when the pedal is up the lights will stay on. same for a bad brake on off switch
Dec 25, 2007 at 1:27 PM
