turn signal flasher?
2001 AUDI A6
WKAPP
Electrical problem 6 cyl All Wheel Drive Automatic 110000 miles
My turn signals click one time and stop either direction?
Nov 22, 2008 at 6:48 PM
It sounds like you have a signal flasher that is out which is integrated into the hazard switch. Here is the location so you can test it out and fix the problem. If that doesn't do it there is a lighting module that I would replace.
Here are some guides and diagram (below) that will help you see what the problem is.
and
Please let us know what happens so it will help others.
Sep 7, 2017 at 2:06 PM
