Have an 2001 Audi A6 (standard) that both the Auxilliary and Condensor fans just stopped working. This happened 4 days after the auxiliary fan was replaced. I have since then replaced the ECT sensor (by the air intake valve) and the Fan Switch (blue sensor all the way at the bottom by the radiator). Checked the standard fuses by the side of the driver’s door and coolant fan fuse (two orange/clear ones) under the steering wheel, which all are functional.
It gets extremely hot and humid here. My concerns above is now causing the A/C to just blow out hot air. I can’t even drive more than 15 miles without getting really soaked even with all the windows down. Have I missed anything out e.g. fuses, switches or sensors? Please help.
NB//There are also solid colored fuses (they may be relays) under the steering wheel, how can I tell if any of them are bad by just looking at them? If any of pertain to making the fans run again.
May 24, 2010 at 11:54 AM
