2000 Audi A6 How to change Bank 2 Sensor 1 O2 sensor?
2000 AUDI A6
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEVINMK2
  • 4 POSTS
Hi... I have a 2000 Audi A6 Quattro with 2.8L engine, got a P0154 error code stating "O2 sensor circuit no activity detected". This code has come and gone on its own, and I'm trying to replace the sensor to fix it. Would you please kindly tell me how to access the O2 sensor and what special tools are needed?
Just some additional information, not sure if it helps:
symptoms: I know this sounds voodoo, but the code seems to come on when its raining and sometimes goes away after it rains. The car experiences rough idle in drive and neutral with RPMs wanting to drop below 600 instead of staying at 700 when the code comes on.
milage: 89000
repairs: changed battery, not changed time belt.
Thanks in advance!
Oct 17, 2009 at 11:16 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you is your model just the A6 or the Quattro or the Avant Quattro.
Oct 17, 2009 at 7:05 PM
KEVINMK2
  • 4 POSTS
My car is an Avant Quattro... much appreciate if you could provide relevant pictures or diagram for the fix.
Oct 17, 2009 at 7:18 PM
IMPALASS
  • 3,112 POSTS
Hello Okay, you have 4 sensors on the vehicle. Here are the banks below. Cylinder bank 1 is located on right side in direction of travel. Cylinder bank 2 is located on left side in direction of travel.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_96.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Picture2_62.jpg
Since your code is Bank 2 Sensor 1 that would be number 15 the one before the cat. You are supposed to follow the directions below using the grease. You may have to get this at the dealer. 1. Heated Oxygen Sensor (HO2S) 2 - G108-* bank 2, 50 Nm Only use "G 052 112 A3" to grease thread; do not let "G 052 112 A3" get onto slit of oxygen sensor You will need to use a special tool you can get it at Auto Zone and you may be able to use their tool check out program if they have that to loan.
https://www.2carpros.com/forum/automotive_pictures/248015_02_Sensor_Tool_1.jpg
Try cleaning your MAF sensor with electrical cleaner. Just spray it really good...the resistors and the fine wire. don't touch it otherwise. just the spray.
https://www.2carpros.com/forum/automotive_pictures/248015_6_27.jpg
Then let's see how it runs
Oct 17, 2009 at 8:35 PM
IMPALASS
  • 3,112 POSTS
Hello - Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://www.2carpros.com/forum/automotive_pictures/248015_Recall_30.jpg
Oct 17, 2009 at 8:41 PM
KEVINMK2
  • 4 POSTS
Thanks for the prompt reply... I was wondering if you could post slightly larger pic for the 1st diagram? I can hardly see a thing there... also, mind kindly pointing out where the MAF sensor's location in this engine bay?
Thanks!
Oct 24, 2009 at 12:28 PM
IMPALASS
  • 3,112 POSTS
Hello - Sure -I will do what I can to blow it up but have you tried right clicking on the pic....saving it to your drive then viewing it as a pic or inserting into a say, powerpoint doc and making it bigger? I have tried several different things but I think that is the best I can do for some reason on that one.
https://www.2carpros.com/forum/automotive_pictures/248015_Begger_GIf_1.jpg
If you need it bigger than this.......and the above doesn't work - I will have to fax it to you or split the pic........ Just let me know. The MAF is located on the aircleaner...........
https://www.2carpros.com/forum/automotive_pictures/248015_MAF_1.jpg
Oct 25, 2009 at 7:39 PM
KEVINMK2
  • 4 POSTS
Thank you Sir! That's very helpful indeed!
I've cleaned the MAF sensor with air intake and since it isn't raining lately all seems well. Crossing fingers that the dreaded check engine light doesn't come on for a long while.
Oct 25, 2009 at 11:25 PM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the update………….hope all stays well………..
Oct 26, 2009 at 9:38 PM
