Removal & Installation (A6)
Disconnect negative battery cable. Remove air intake duct. Remove 10 screws retaining under-car splash shield and remove splash shield.
Place lock carrier in service position. See Fig. 2 . Remove connector bolt. Install Alignment Tool (3369). See Fig. 3 . Remove Torx bolts.
Remove remaining bolts and pull lock carrier forward. Tighten lock-down bolts on left and right side to place lock carrier in service position. See Fig. 4 .
Remove serpentine belt. Disconnect wiring from generator. On A/C equipped vehicles, remove A/C line bracket and position A/C line out of way.
Cut cable tie-wraps from generator/starter harness and position harness out of way. Remove upper and lower generator bolt. Remove generator from bottom of engine compartment.
To, install, reverse removal procedure. Ensure generator/starter harness is tie-wrapped in proper position. Tighten upper generator bolt to 33 ft. lbs. (45 N.m) and lower bolt to 16 ft. lbs. (22 N.m).
Nov 23, 2008 at 8:01 PM
