1999 Audi A6
1999 AUDI A6
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
1ROMIK
  • 12 POSTS
The power windows, power door locks, interior lights, and power moonroof all stopped working. Can you please tell me if these items are all related to one thing, if yes or no, what is the fix please?
Nov 16, 2008 at 9:58 PM
JAMES W.
  • 2,394 POSTS
The control for these units is on the same fuse. You should check "all" the fuses.
Nov 16, 2008 at 10:21 PM
IMPALASS
  • 3,112 POSTS
Hello - If you need to get back with me, there are different models Audi A6s. Please let me know from the below Pic.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture5_2.jpg
Next, check fuse number 6. Fuse arrangement in fuse panel, behind instrument cluster, left
https://www.2carpros.com/forum/automotive_pictures/248015_Picture6_2.jpg
All theses systems run through your Central Locking Control Module located under the driver's seat and carpet.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture4_3.jpg
You might also check to see if a plug was disconnected under the seat. When you check the fuse, please make sure you use an ohm meter or replace with a known new fuse. Even a blown fuse can look good. Let me know what you find.
Nov 16, 2008 at 10:47 PM
