Hi pick,
Thank you for the donation.
REAR DOOR TRIM, REMOVING AND INSTALLING
1. Door trim ï‚¡ Remove screws -2- (2x) from door trim -1-. ï‚¡ Remove window regulator switch unit -5-. ï‚¡
Lift door trim about 20 cm upward and remove from door. ï‚¡
Detach Bowden cable for interior door handle. See DETACHING BOWDEN CABLE . ï‚¡
Disconnect electrical connectors. See DISCONNECTING ELECTRICAL CONNECTORS .
Clip locators -3- (6x) and -4- (1x) must be clipped in place when installing door trim. When installing, press center of door trim onto door.
2. Screws (2x) ï¬ Tightening torque: 1.5 Nm (13 in lb)
3. Clip locators
4. Clip locators
5. Window regulator switch unit
Detaching Bowden cable ï¬ Pull Bowden cable -1- out of guide -2- and detach.
Fig. 36: Detaching/Installing Bowden Cable Courtesy of AUDI OF AMERICA, INC.
Disconnecting electrical connectors ï¬
Disconnect connector for door warning light -2-. ï¬
Disconnect connector for loudspeaker -1-.
Fig. 37: Disconnecting Electrical Connectors - Rear Door Courtesy of AUDI OF AMERICA, INC.
NOTE: When installing, make sure hook -3- is facing upward.
Page 1 of 1 INTERIOR TRIM -1998 Audi A6 9/17/2008
Sep 17, 2008 at 7:11 AM
