1997 Audi A6 replacing radiator
1997 AUDI A6
152,000 MILES • 6 CYL • AWD • AUTOMATIC
GLENN VANFOSSEN
how do i replace the radiator without disconnecting the a/c line
Feb 4, 2010 at 9:05 AM
AUTOMD
  • 50 POSTS
you could transfer the cooler lines into the new radiator by putting up the 2 align rubber plugs into the beam, it will be easier that way to center the radiator, you can install the lower radiator hose from the top or from the bottom if the fans are out
Feb 10, 2010 at 2:33 AM
