mine seems to be fried and in need of replacement. the gear indicator on the dash used to light up an signal which gear it wsa in. then the switch woiuld slip and it would indicate the tranny being in ALL gears at once though only shifting in park, reverse, nuetral and drive, except when in drive it will only recognize being in first gear or low. however now the gear indicator is completely dark adn doesnt shift from out of first gear?drive. how involved is the replacement? know anywhere where i can find a used or cheap replacement? could there be another problem with the transmission?
Feb 12, 2010 at 2:05 PM
