Wiring diagram needed for 16-pin piggyback
1998 AUDI A4
18,640 MILES • 2.6L • 6 CYL • TURBO • 2WD • MANUAL
TANYA4027
  • 4 POSTS
Good day,
Someone tried to steal my vehicle. They have cut and pulled out all the wires out of the connector D on the ECU.
If someone may kindly assist me. I just need to get an auto electrician to re-wire. I live in South Africa, and the auto electricians tell me the same story they need a schematic diagram or photo of the wires that plugs into the plug.
The 16-pin plug 443 972 805. I need the color wire diagram on the 16-pin piggyback plug. I really need to get my car sorted out for my children.
If someone may please help me urgently.
Thank you,
Tanya
Audi A4 2.6 ABC Hella 4A0 907 473 P MPFI+ASR 5DA 007 193-13
Nov 22, 2021 at 5:00 AM
I attached the wiring schematics below for a V6, but it indicates it to be a 2.8L and not a 2.6L. Also, you show it as being turbo. The only turbo model we have is a 1.8L.
As far as the schematics, I had to cut each one in half to make them readable for you. I did overlap them so you can follow from one to the next.
See pics below.
Nov 22, 2021 at 8:59 PM
TANYA4027
  • 4 POSTS
Thank you very much it is highly appreciated. I see on the diagrams it says Motronic. My Audi has a Hella computer box. As far as I know the Motronic and Hella differs from one another. I have bought a new 16 pin plug. Like I say I just need to make sure what color wire goes into what pin on Connector D.
Nov 22, 2021 at 10:28 PM
The Motronic is the only one I'm showing. Tell me this. Is the engine size you listed correctly? If it isn't, are you in the US?
Nov 23, 2021 at 5:09 PM
TANYA4027
  • 4 POSTS
The engine size is a 2.6L yes, it is correct. I do not live in the USA. I life in South Africa.
Nov 23, 2021 at 11:23 PM
Thanks for the update. That was my concern. Because it isn't one offered here, I don't have the 2.6L information. So, the information I provided is likely incorrect.
I feel bad that I couldn't be of more help. Please let me know if there is anything I can do to help you.
Nov 24, 2021 at 8:50 PM
TANYA4027
  • 4 POSTS
Thank you for trying to help. It is highly appreciated. Thanks for all your trouble.
Nov 24, 2021 at 11:00 PM
No trouble at all. I feel bad I don't have what is needed. Please feel free to come back in the future if there is something I can help you with.
Take good care of yourself,
Nov 24, 2021 at 11:23 PM
