2008 Audi A4 AC Drain to Outside
2008 AUDI A4
8,000 MILES • 4 CYL • AWD • AUTOMATIC
RALPHIE1
There is a moldy, musty odor from vents while using AC. I noticed that there never seems to be liquid drained to the outside from the evaporator. The mechanic says the drain tube is not plugged. In this type of car what triggers the evaporator to drain the liquid? Is there a sensor which controls this? Thanks
Apr 14, 2009 at 12:58 PM
DOCFIXIT
  • 18,828 POSTS
No it drains out via gravity. As the evap removes moisture it collects and fan air flow helps drain.
Apr 14, 2009 at 3:49 PM
