2003 Audi A4 stalling engine
2003 AUDI A4
92,000 MILES • 4 CYL • AWD • AUTOMATIC
DWOOD44
My 2004 Audi A4 1.8T quattro sometimes stalls after I start it. It always starts on the second try. I have only owned it for a week. What could be causing this?
Aug 28, 2009 at 10:02 PM
DUBTECH
  • 159 POSTS
Possible vacuum leak or problem with the throttle body.
Usually the throttle body only requires a cleaning and adaption. It will need to be done by somebody who has access to a VW scantool because of the adaption required after cleaning.
Aug 31, 2009 at 2:18 PM
DWOOD44
Thank you! I just had the throttle body cleaned before I purchased it from the dealership (not Audi or VW). I bet they did not perform the adaptation because they probably don't have a VW scantool. I'll take it to the right place this time (:
Aug 31, 2009 at 4:19 PM
DUBTECH
  • 159 POSTS
[quote:5411488fc1="dwood44"]Thank you! I just had the throttle body cleaned before I purchased it from the dealership (not Audi or VW). I bet they did not perform the adaptation because they probably don't have a VW scantool. I'll take it to the right place this time (:[/quote:5411488fc1]
Sounds like it may be a simple solution then. Glad to help...
Aug 31, 2009 at 6:53 PM
