2003 Audi A4 rear power windows
2003 AUDI A4
65,000 MILES • 4 CYL • FWD • AUTOMATIC
ERIC FRALEY
rear d side powere window slides down if i hit a bump. it will go down if i use the down switch. will not go up if i push up on power switch. is motor bad/ window off track? could i attempt to fix?
Jul 5, 2008 at 7:42 PM
DOCHAGERTY
  • 9,603 POSTS
An attempt is possible if you have the tools and parts required and the skill to attempt the repair. If you try you can do it. I recommend getting the correct repair manual as well, good luck and let us know the results
Jul 5, 2008 at 7:52 PM
RJJ 1
  • 16 POSTS
you probably have a bad window regulator you could replace it yourself but you have to disassemble the door ,better left to a pro
Jul 27, 2008 at 12:19 AM
