HI there,
This does sound ominous, i would start with a comp test, and check the oil pressure with a mechanical gauge, if the knock is a deep hollow knock constant with engine speed, this well may be a failed main bearing, you will need a mechanic to listen to this to confirm the diagnosis.
Mark (mhpautos)
Dec 4, 2009 at 9:50 PM
