I've replaced my outside temperature sensor (twice in 2 weeks after having no luck with the first replacement). The problem is that intermittently my temperature reading on the instrument cluster reads -45 degrees. Trouble is, when this happens, the A/C "thinks" that it's plenty cold outside and all I get in blasting hot Arizona heat coming into the cabin. I'm convinced that the sensor is working correctly, so now I am wondering if something is faulty within the instrument cluster itself. As near as I can determine, the wiring is essentially outside temp sensor --> instrument cluster --> A/C (as an overide). Any ideas?
Thanks.
Thanks.
Apr 30, 2009 at 8:42 PM
