First: My check engine light came on few days ago, I take to Autozone to get fault code. They said either faulty air selenoid valve orfaulty air pump motor, Is this problem easy to fix?
Second: Low oil warning light came on, I check oil level, it is ok, warning light only came on when I drive at high speed, can you help me. Thank you
Jan 25, 2010 at 6:19 PM
