2001 Audi A4 Help
2001 AUDI A4
131,000 MILES • 4 CYL • 4WD • AUTOMATIC
LUBO64
i have changed everything possible in my car including the oil pump and oil pressure switch four times...the problem is that the red oil light shows up on the dash. the engine runs great with no problems, and there is no noise, again the light keeps coming on though. do you know what it could be?
Sep 2, 2010 at 7:36 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This will be an earth type switch, i would be thinking that the sender wire is grounded causing the light to come on, that is if the pressure is correct did you test it with a mechanical gauge?
mark (mhpautos)
Sep 2, 2010 at 8:02 PM
