2001 Audi A4 camshaft tensioner
2001 AUDI A4
124,000 MILES • 4 CYL • FWD • AUTOMATIC
ANDREW SINTON
the noise is coming from the tensioner i believe i took the valve cover off and started the car and the tensioner is moving up and down i assume the tensioner should stay snug and the chain should ride on the guide is this correct if so is it easy enough to replace the tensioner
Mar 17, 2009 at 7:50 AM
DOCFIXIT
  • 18,828 POSTS
Do you have a 1.8 L? This engine uses a timing belt.
Mar 17, 2009 at 8:16 AM
ANDREW SINTON
this car has a 1.8L it has a timing belt this is a chain & tensioner on the back side of the camshaft
Mar 17, 2009 at 9:04 AM
DOCFIXIT
  • 18,828 POSTS
O.K. there is an adjuster on tensioner small hex screw.
You can try a small adj. do not over tighten. As long as guide is not worn. Also see if cam marks line up with mark on bearing .
Mar 17, 2009 at 9:28 AM
ANDREW SINTON
thank you for answering me is this normal for the tensioner to go up and down as the car is running or should the tensioner just have tension on the chain the piston on the tensioner goes up and down like it is riding on a lobe of the cam
Mar 17, 2009 at 10:48 AM
DOCFIXIT
  • 18,828 POSTS
Should not move it's purpose is to keep chain tight.
Mar 17, 2009 at 11:40 AM
