Hey Groovis.
I was just making sure all base's were covered ! I have listed the most common faults on C/L system and causes you will need to check these !! of course the fault could be in the control module .. so it really could also do with scanning with a VAG diagnostic scanner !!
DTC 01360: DRIVER'S DOOR SWITCH
NOTE:This DTC is usually stored because of improper use of alarm system. Only carry out repairs if a complaint exists, otherwise just erase DTC. See FUNCTION MODE 05: ERASING DTC MEMORY under SELF-DIAGNOSTIC SYSTEM.
Possible Cause
Short to ground in wiring. Faulty driver's side door switch.
Corrective Steps
Repair short to ground in wiring. See WIRING DIAGRAMS . Replace driver's side door switch if necessary.
DTC 01361: PASSENGER'S DOOR SWITCH
Possible Cause
Short to ground in wiring. Faulty passenger's side door switch.
Corrective Steps
Repair short to ground in wiring. See WIRING DIAGRAMS . Replace passenger's side door switch if necessary.
ENTERING ON-BOARD DIAGNOSTIC FUNCTION MODES
NOTE:Additional operating instructions can be obtained by pressing HELP key on scan tool. During test procedures, the right arrow key advances program to next step. An incorrect entry can be cancelled with "C" key.
DTC 01367: CENTRAL LOCKING PUMP
Possible Cause
Pressure in air lines too low. Faulty central locking pump.
Corrective Steps
Check air lines for leaks. Check central locking pump. Check all actuating components of central locking system and replace as necessary.
Ensure battery is fully charged, fuses are not blown, and ground connections are okay. Ensure all accessories are off. Using Adapter Cable (VAG 1551/3), connect Scan Tool (VAG 1551) to Data Link Connector (DLC). If V.A.G SELF DIAGNOSIS HELP 1-RAPID DATA TRANSFER 2-BLINK CODE OUTPUT is displayed on scan tool, go to next step. If V.A.G SELF DIAGNOSIS HELP 1-RAPID DATA TRANSFER 2-BLINK CODE OUTPUT is not displayed on scan tool, check battery, fuses, ground and scan tool for proper connections.
Hope this helps, let me know !
Mar 19, 2009 at 6:50 AM
