Just had transmission changed, used with 104,000 miles, the car has 198,000. Had filter and oil changed after installation, installed the new transmission with same brain and multifunction switch that came woth new transmission. The car is in limp mode and cannot reset. Tried several times, even changed to old multifuntion switch and TCU, and still not able to reset the computer. Car drives fine on third gear it seems to be stuck on, slow starting but goes fine , no noise, just won't shift. can you help? It's doing the same as when old transmission was in place, but Aamoco locally said they need to rebuild it. Thought was cheaper just to change to a good used trany. also when shifting from P to R or D it makes a clangging noise, like something is loose. Thanks
Apr 7, 2010 at 2:08 PM
