Engine Performance problem
1998 Audi A4 4 cyl All Wheel Drive Automatic 200K miles
At wits end, hope you can help- Check engine light flashing. Dx gauge shows engine misfire cylinder 1, I think it was code P0301. Changed spark plugs, swapped 1 and 3 injector, ran compression tests, changed fuel pump, same code comes up, same cylinder misfiring. Any suggestions as to where to go next?
Jul 8, 2009 at 9:01 PM
